Picked up a Sine Wave Generator
I just picked up a sine wave generator that I plan to use for setting up and verifying tunes. I do most if my testing on a stim in the basement. I plan to use this for simulating things like wheel speed sensors. I will test by feeding signals into my MS3 Ultimate or the I/O box out on the CAN network.
http://www.nbs-stl.com/tuning/Sine%20Wa ... erator.jpg
I picked it up on Ebay for about $60 The scope was found on Ebay for about $175
Andy
Andy
Re: Picked up a Sine Wave Generator
Pretty. Is it able to send a missing-tooth signal?
Not that I know of as a setting. There is a way to create and save a custom signal
Clearly very useful equipment.
Regarding the creation of a pulse train with missing tooth I imagine a low cost, type Arduino, single board computer would be usable, also for creating other types of signals.
Martin, Sweden
Mopar 512 cui, 8.4 liters, high compression, fuel E85, full sequential control by MS3X, burning rubber just blipping the throttle...
Have you looked at Ardustim. https://blogs.libreems.org/arduino-wheel-simulator/
With an Arduino you can generate a multitude of wheel patterns and also a cam signal.
As a side note I am the guy that you helped over the phone many years ago to set up some X-Bee modules for remote datalogging.
I still have that XBee setup. Antenna and all.
