I am almost ready to plug in my MS3X on my MR2 Gen 3 turbo project.
Does anybody have a MS3 compatible MSQ/Base map for a Gen 3 MR2? or Celica ST205?
This is my first Megasquirt tuning project so it would be good to get a jump start using a base map that I know should at least get it started.
Dan
Anybody have a base map for a Gen 3 MR2 3SGTE? (or ST205)?
Re: Anybody have a base map for a Gen 3 MR2 3SGTE? (or ST20
I simply used the base map off the MS site for my gen 3 3sgte installed in a MR2 using the MSPNP v2. Tune worked fine for start up and run until I bought the registered copy to use VEAL.
Jim
Jim
Toyota MR2 98 3sgte
MSPNP2 with 3.57 mainboard
TD05SL2-18g with external WG
HKS EBC running 17psi boost.
I could only find a base map for gen2 3sgte on the site, it's there a gen 3 one hiding somewhere?
Base maps are much the same between versions. When you set up tune the required fuel is entered based on engine and injector size with the gen 3's running 540's.
Jim
Jim
Toyota MR2 98 3sgte
OK cheers I'll start off with the gen 2 then, change the injector size and see how far i get.
Cheers
Dan
Cheers
Dan
