I was having trouble getting rock solid timing using the stock Honda 24 tooth crank sensor even after I tried a Hall sensor for the cam sync. I was also fighting starting issues and sync issues. I wanted to go to more teeth so the ECU will see a tooth every 18 crankshaft degrees compared to 30 degrees with the 24 tooth wheel. I purchased the following parts.
A 40 tooth 2.5" OD steel gear from an online supply house
A 3/8" OD threaded Motec Hall sensor designed for motorcycles
A Accel points eliminator optical pickup that required a pullup resistor
http://www.nbs-stl.com/CrxTypeR/Dizzy%201.jpg
http://www.nbs-stl.com/CrxTypeR/Dizzy%202.jpg
http://www.nbs-stl.com/CrxTypeR/Dizzy%203.jpg
http://www.nbs-stl.com/CrxTypeR/Dizzy%204.jpg
http://www.nbs-stl.com/CrxTypeR/Dizzy%205.jpg
http://www.nbs-stl.com/CrxTypeR/Dizzy1.jpg
Here is the composite log with me reving the motor.
http://www.nbs-stl.com/CrxTypeR/40%20to ... %20log.csv
The timing appears to be rock solid with no drift and easy starting. I had to purchase 6 of the gears and only used one. Contact me if anyone can use a 2.5" OD, 12 mm ID gear.
Hope this helps people that may be fighting similar issues.
Andy
Converting a Honda Dizzy
Re: Converting a Honda Dizzy
Thats a nice set up. If I ever to a I4 with MS2 i'll give that a try.
Can you repost the pics please?
I think I still have one of the gears I used.
- Attachments
- Capture23.JPG (134.55 KiB) Viewed 445 times
- Capture24.JPG (53.42 KiB) Viewed 445 times
