Programmable output variable “seconds after engine start”
joshclifford84
Post by joshclifford84 »
I need to activate a programmable output based on time after successful start. I don't think it exists(based on the options) but hoping someone has advice?
nathaninwa
Re: Programmable output variable “seconds after engine start
Post by nathaninwa »
I can a fuel pump prime with second and less than rpm, you should be able to program one with greater than seconds and greater than X rpm, like 400 or something
Edit. Maybe, might have to use the equal too on this one
dontz125
Post by dontz125 »
Unless I'm mistaken, 'seconds' is since the MS was powered up, not since engine start. It works if you crank immediately after key-on and priming, but any delay in start-up could mess up the timing.
jamies
Post by jamies »
it may be possible to enable the GM hei bypass which switches the output on a few seconds after the engine is running,
otherwise it may need to be a custom firmware modification
slow_hemi6
Post by slow_hemi6 »
maybe there is a different approach. What are you trying to do/achieve?
Cheers Luke
