4AGE Coil Over Pack (COP) Conversion Settings
aukword1
Re: 4AGE Coil Over Pack (COP) Conversion Settings
Post by aukword1 »
okay makes sense. So basically, whatever tooth is at #1 I have to set the angle to match it correct? So lets say my tooth is at btdc and then I'd set it at 0?
dontz125
Post by dontz125 »
? Please re-read what you wrote, because it's hurting my head ... :lol:
aukword1
Post by aukword1 »
Sorry was kinda boozy when I wrote that. So basically since I have only 4 teeth on my distributor, I can only have four possible scenarios correct? (90, 180, 270, 360). When the engine is at tdc, the dizzy will usually be around the 1 plug which would make that 90 degrees correct? So unless my timing is off, my degree angle should be set to 90. Unless I am misunderstanding where the angles are coming from and have to get a degree wheel for the cams.
dontz125
Post by dontz125 »
If your ignition timing spans a range of 10-30 degrees BTDC, the towers are probably at 20*. The actual VR teeth will be significantly in advance of that, because you need to dwell the coil before the rotor gets to the firing position.
In TS, under Ignition Options / Wheel Decoder, set [Fixed Advance] (top of the right side) to "Fixed Timing". [Timing for Fixed Advance] (just below Fixed Advance) is typically 10deg for this operation. Crank the engine over, and check the timing advance for the #1 cylinder. If it ISN'T 10deg (or whatever you have it set to), adjust the [Tooth #1 Angle] until the timing light reads 10deg BTDC.
aukword1
Post by aukword1 »
I think I understand. But, I am still unable to get the car running to check the timing. Would you have to adjust any of the fuel injector settings when running a sequential ignition setup?
suberimakuri
Post by suberimakuri »
Keeping in mind engine cycle is 720 degrees...
Follow this to find tooth 1 angle and/or use dontz125 method.
http://www.msextra.com/doc/pdf/html/MS3 ... 4-150.html
Re: Fuel Injectors.
You need to set the outputs that you are using, eg mainboard or MS3X.
Whether you actually do sequential fuel injection is another matter. You could just do batch injection and that would be fine.
You really need to go through the TunerStudio manual for the relevant sections.
slow_hemi6
Post by slow_hemi6 »
Somebody needs to correct me if I am wrong, but I will take a shot at this also. From what I have seen the 4/1 has 4 teeth, each one 180 crank degrees apart. Plus a cam tooth (upper) that occurs 10 crank degrees after one of the 4 lower teeth.
As you are using Dual Wheel you have a crank input (4 teeth/720 crank degrees) and a cam input (1 tooth/720 crank degrees).
Tooth #1 is the first(lower) tooth to pass the main sensor after the single(upper) tooth has passed the second sensor.
So you need to put the engine on TDC compression cyl1. Then turn the engine backwards till the upper single tooth lines up with it's sensor.
Now turn the engine forward till the next lower tooth lines up with it's sensor. Should have had to turn about 170 crank degrees.
MS now needs the amount of crank degrees you have to turn in the forwards direction to get back to TDC compression cyl1, entered into the Tooth #1 Angle btdc setting.
That should get you close enough to use a timing light to fine tune the tooth #1 angle with fixed timing.
aukword1
Post by aukword1 »
Okay I will try that method to gain the angle. Also, I noticed that I am not getting an rpm signal when I am cranking the engine. Is this normal?
dontz125
Post by dontz125 »
No displayed rpm signal means the MS doesn't know it's turning, or can't figure out what it's being told. No rpm = no spark & no fuel; rather explains why the engine isn't coughing when you crank it.
Check your sensor wiring & settings.
suberimakuri
Use the composite logger in TunerStudio to confirm whether or not the ecu is seeing the teeth pass the sensors.
Once you've confirmed the right number of teeth are showing (both crank and cam) then it will be a timing or setting issue.
It takes a few moments for the logging to start. Read the Tuner Studio manual for specific instructions.
It will take a lot of cranking which is hard on battery/etc. You may want to spin the dizzy in a drill first to confirm the signals... albeit most drills won't go down to 100-200rpm cranking speeds.
aukword1
Post by aukword1 »
This may be a dumb question but on the MSPNP gen 2 I noticed that it has jumpers on the mainboard for IGN A/C and IGN B/D. I assume I have to set these jumpers to run in sequential control via AELD and WLED correct? Maybe this is my issue?
Post by Matt Cramer »
Yes, you do need to set a couple jumpers to get all four spark outputs.
aukword1
Post by aukword1 »
Okay, thats what I figured. I wired my COP's to a waste spark mode, basically just Spark A output to COP's 1 and 4 and Spark B to 2 and 3 just to see if it would work that way. Still no rpm signal. Went into test mode to see if the coils would fire. Only spark plug 1 was firing. I will bench test the other 3 coil packs just to make sure they are working, if not I might have to replace them. Also I will do the composite logger today to see if the teeth are being detected (seeing is that is the main issue so far). Will update with results.
aukword1
Post by aukword1 »
nothing being picked up on the composite logger. Just gonna source an EDIS system and delete the whole distributor.
aukword1
Post by aukword1 »
Anyone know what wire I would need to send from my distributor to the cam sensor input on my ECU?
CRSTune
Post by CRSTune »
It should be a green wire.
I'm in the VA/DC area! Let me know if I can help you locally! I offer tuning and troubleshooting services.
http://www.msextra.com/forums/viewtopic ... 37&t=64269
Email me directly at CRSTune@gmail.com
Personal Vehicle:
'92 Nissan 240sx, KA24DET, GT2860RS, MS3X, Coil-on-Plug
suberimakuri
For Edis or Toyota?
The wire colours often change at the plug so best to take dizzy cap off and trace from appropriate sensor.
aukword1
Post by aukword1 »
For Toyota, apparently that is what I am missing from my setup. The ECU isn't even reading the distributor as a cam sensor. So I figure if I wire that to the input on the ECU for the cam sensor then it should read it. Will update later tonight with results.
dontz125
Post by dontz125 »
I've lost track - how many teeth does the cam wheel have?
CRSTune
Post by CRSTune »
dontz125 wrote:I've lost track - how many teeth does the cam wheel have?
4 crank, 1 cam. Both are at camshaft speed.
Personal Vehicle:
