4AGE Coil Over Pack (COP) Conversion Settings
dontz125
Re: 4AGE Coil Over Pack (COP) Conversion Settings
Post by dontz125 »
Thanks. Can we get the current .msq posted up? The last one I saw was set for Basic Trigger ...
aukword1
Post by aukword1 »
one moment my friend...
aukword1
Post by aukword1 »
here you go.
dontz125
Post by dontz125 »
dontz125 wrote:Can we get the current .msq posted up?
(The TS tune file; you posted a .msl log file. :P )
aukword1
Post by aukword1 »
sorry here you go.
dontz125
Post by dontz125 »
You've got it set for 'Wasted COP'; it should be set to 'Wasted Spark.' It should't be a deal breaker, but it isn't right and might be confusing things.
aukword1
Post by aukword1 »
Ive tried both settings and still no rpm signal..i think the ecu isnt reading the distributor as a cam signal.
dontz125
Post by dontz125 »
Do you have the correct sensor wired to the right input? That is, is the 4-tooth wheel hooked up to VR1? If it's hooked up to VR2, it's not going to work.
aukword1
Post by aukword1 »
How do I know which is VR1 and VR2?
dontz125
Post by dontz125 »
It should be labeled.
aukword1
Post by aukword1 »
well looks like you are right and my distributor wont work. I will try to find an EDIS 4 setup. I went to the junk yard today but couldn't find any. I found a few ford taurus's but couldn't find the EDIS 4 module as directed in the manual. I saw that they had a VR sensor and a toothed wheel though. I will try another bone yard next week.
CRSTune
Post by CRSTune »
aukword1 wrote:well looks like you are right and my distributor wont work. I will try to find an EDIS 4 setup. I went to the junk yard today but couldn't find any. I found a few ford taurus's but couldn't find the EDIS 4 module as directed in the manual. I saw that they had a VR sensor and a toothed wheel though. I will try another bone yard next week.
Use the later model 20V distributor. They're known to work well. Granted, a crank mounted trigger wheel is superior but the 20V CAS is much simpler to install and configure.
I'm in the VA/DC area! Let me know if I can help you locally! I offer tuning and troubleshooting services.
http://www.msextra.com/forums/viewtopic ... 37&t=64269
Email me directly at CRSTune@gmail.com
Personal Vehicle:
'92 Nissan 240sx, KA24DET, GT2860RS, MS3X, Coil-on-Plug
aukword1
Post by aukword1 »
do you happen to know if the 20v will fit in the 16v? or if autozone/o'reily's would sell it?
CRSTune
Post by CRSTune »
I had to double check but it looks like it's a 20V only fitment. Sorry for the misinformation.
Personal Vehicle:
aukword1
Post by aukword1 »
No worries, I went to the junkyard today and got an EDIS4. I had to get the VR sensor off an EDIS6 but it looks like it should work. Will probably try to install it next weekend.
suberimakuri
Post by suberimakuri »
The JDM 16V distributors have 24/2 wheel. If you get later model smallport 4age engines then these may also have this distributor.
However it sounds like you don't have it wired correctly (VR1 +- VR2) and if appropriate the relevant board jumpering.
If it was, then we would see the 4/1 teeth in the tooth logger.
Troubleshooting VR setups is a real pita and as this is all new for you (not a bad thing! welcome! :)) I agree that EDIS is probably an easier way to go.
Keep at it, won't be long.
dontz125
Post by dontz125 »
Ummm ... Point of order? If the OP is planning to install and run an EDIS module, then he MUST have (or is willing to install) a 36-1 crank wheel. If there is (or can be) a 36-1 crank wheel, why the dancing around with a 4/1 dizzy?
suberimakuri
Personally I like the 24/2 dizzy's, but whatever. Clean installation, no custom stuff... but found MS3X best. MS2 was okay with LM1815 circuits.
Looks like can get a trigger wheel for EDIS here:
https://technotoytuning.com/toyota/16v4 ... gger-wheel
Looks like need to use their crank pulley as well.
No mention of a trigger mount.
aukword1
Post by aukword1 »
Yeah that's where I was gonna order the trigger wheel from, I wanted to do the 4/1 dizzy because I already had it. I'd prefer the 24/2 dizzy but it seems hard to find right now. I will keep trying the 4/1 dizzy until the trigger wheel and crank pulley come in though. I haven't given up yet and made some sort of breakthrough last night with the rpm signal. At least if I can't get the 4/1 to work then I have a backup EDIS system to try. Will keep you guys updated.
aukword1
Post by aukword1 »
Update*
I almost got the car started on a wasted cop setting(it had a small ignite in the cylinders) with my igniter still hooked up (but unplugged from the distributor) to send the rpm signal to the ECU. I believe my tooth #1 degree is off and that is why it didn't fully start. I will print out a degree wheel to attach to the crank and degree the distributor teeth according to the megasquirt manual. I will update with my results. Thank you all for your help!
