PCV issues
PCV issues
I experienced a situation where, coming off high rpm, the engine creates a large amount of vacuum and it effectively sucks oil through the pcv into the intake manifold. Now the engine is non-standard so the Original pcv with it's spring actuated pintle is not suited for the engine. I use fixed orifice type PCV with an oil catch can in between.
To combat the situation, would connecting the outlet of the PCV to the airbox (ITB system) be an alterntive ?
Re: PCV issues
You need a sprung PCV when connecting to the manifold. The spring prevents exactly the problem you had.
Or change to no PCV and vent into a can.
Re: PCV issues
What makes a spring-type not suited for you engine?Yves wrote:I experienced a situation where, coming off high rpm, the engine creates a large amount of vacuum and it effectively sucks oil through the pcv into the intake manifold. Now the engine is non-standard so the Original pcv with it's spring actuated pintle is not suited for the engine. I use fixed orifice type PCV with an oil catch can in between.
There are adjustable type out there too.
'69 Bronco, lifted, coiled, linked, locked, caged, ZF5, Atlas II, BB 9inch/HP44, 37s
MicroSquirt, roller 351W .030"over, FAST throttle body, alum heads/intake, header, forged rotating bits. 370HP / 440 lbft daily driver
Re: PCV issues
Can you point me to one. At the time I was checking into these I only found the ones that you couldn't set.
Re: PCV issues
The pcv's for my engine have a 3/4" hose and no regulation of the spring force. What happens is they are full open at anything except decel which acts as a very big vacuum leak.jsmcortina wrote:You need a sprung PCV when connecting to the manifold. The spring prevents exactly the problem you had.
Re: PCV issues
I am confused, if your PCV valve has a spring it should be closed under full throttle and wide open under decel.Yves wrote:The pcv's for my engine have a 3/4" hose and no regulation of the spring force. What happens is they are full open at anything except decel which acts as a very big vacuum leak.jsmcortina wrote:You need a sprung PCV when connecting to the manifold. The spring prevents exactly the problem you had.
How exactly do you have your PCV valve system plumbed?
David
Re: PCV issues
"I am confused, if your PCV valve has a spring it should be closed under full throttle and wide open under decel."
Yes, I think you are confused. That is opposite to all I have worked with, and that goes back to when they first became required in 1965.
Re: PCV issues
Are you saying with out vacuum the valve is open and with vacuum the valve is closed?
David
EDIT: I am not talking about the breather side but the valve it self.
David
Re: PCV issues
Re: PCV issues
Yes, manifold vacuum closes the PCV valve to restrict flow. It has to be installed in the correct direction though...
All PCV valves I have seen have just a single hose barb for the hose to a manifold, with the other end going into a grommet on the engine; so installing "backwards" would be a very difficult mistake to make.
Re: PCV issues
This is the one I havecactus wrote:I've been curious to hear other impressions about this adjustable PCV valve.
http://mewagner.com/
Re: PCV issues
Of course...billr wrote:Yes, manifold vacuum closes the PCV valve to restrict flow. It has to be installed in the correct direction though...
However the spring is set according to engine vacuum. If your vacuum is lower than what the engine for which the valve is designed for has, then it's going to stay open.
Re: PCV issues
Then you need a PCV valve with a weaker spring, or a better "adjustable" one. Just how bad is your idle vacuum?
Re: PCV issues
8 inchHg
Re: PCV issues
That should be enough. If I had to, I would cut open a stock valve and change out the spring; make my own "adjustable" one.
Re: PCV issues
The article James posted says under high vacuum the valve moves against the spring restricting vacuum, it does not close the valve.
At full throttle or atmosphere the PCV valve does not have vacuum rendering it ineffective hence the breather side now acting as the vacuum source.
If you put a catch can in the the PCV valve side and the breather side you can eliminate oil in the intake manifold, that's all I have to say about that.
Forest Gump
Forest Gump
Re: PCV issues
The breather clearly doesn't stop the oil being sucked through.
Re: PCV issues
That is why I use 2 catch cans.Yves wrote:The breather clearly doesn't stop the oil being sucked through.
David
Re: PCV issues
Yves wrote:8 inchHg
That's your problem. You don't have enough vacuum to shut or throttle the valve at idle, making your PCV unsuitable for your setup. However an orifice is not the answer either. You need to buy a PCV valve that is matched to your idle vacuum or buy an adjustable.
Also important, do you have proper baffling in your valve cover? This will also cut down on the amount of oil sucked into the intake.
