PCV issues
Re: PCV issues
why run the pcv valve at all, you have itb's and the manifold isn't really set up for the pcv, Just use a large breather for each valve cover going to a oil separator/catch can and skip oiling the intake runners. I haven't run a pcv with itb's and never had any problems, the large breathers get rid of crankcase pressure and the intake doesn't suck oil.
Re: PCV issues
Just breathers alone isn't good enough for long engine life. You need to get some fresh air going in there to dilute the "acid rain" vapors caused by combustion products in the blow-by. Before PCV valves, road-draft tubes were used for this purpose, and had been there in most engines since very early times (1920s?)
Re: PCV issues
You can also run an external vacuum pump. Although these are mostly used in race cars and generally do not last that long.
http://www.buildpics.org/
Re: PCV issues
Exactly, currently I have connected the Pcv to my airboxes in the hope that in that way some vapors will be sucked into the engine. NonethelessI don't think the vacuum is enoughbillr wrote:Just breathers alone isn't good enough for long engine life. You need to get some fresh air going in there to dilute the "acid rain" vapors caused by combustion products in the blow-by. Before PCV valves, road-draft tubes were used for this purpose, and had been there in most engines since very early times (1920s?)
Re: PCV issues
Yes there is baffling.Digger wrote:Yves wrote:8 inchHg
That's your problem. You don't have enough vacuum to shut or throttle the valve at idle, making your PCV unsuitable for your setup. However an orifice is not the answer either. You need to buy a PCV valve that is matched to your idle vacuum or buy an adjustable.
Also important, do you have proper baffling in your valve cover? This will also cut down on the amount of oil sucked into the intake.
Re: PCV issues
how about the exhaust evacuation/suction tubes they weld into the collector to pull a vacuum on the crankcase, you might need some more baffles in the valve covers, I don't know how much vacuum the collectors pull, but I have seen them on several cars, just cant remember if there ok for street use. might pull to much vacuum for daily driver.
Re: PCV issues
Long time ago I had that, but on the street with a muffled car, they don't work.kaeman wrote:how about the exhaust evacuation/suction tubes they weld into the collector to pull a vacuum on the crankcase, you might need some more baffles in the valve covers, I don't know how much vacuum the collectors pull, but I have seen them on several cars, just cant remember if there ok for street use. might pull to much vacuum for daily driver.
Think I'll stick with the current setup of connecting the pcv to the air boxes. Not ideal, as ideally you would want as much of the gases being pulled out, but it's not any worse than a road draft system.
