high rpm miss
high rpm miss
I have a High rpm miss/ backfire thru exhaust. Procharged Sbc 14lbs, 60-2 crank wheel with hall sensor and vortec distributor for the cam signal, cnp with truck coils, ms3 pro. Car runs and drives ok, just above 5000 rpm it acts up. I have been pulling fuel away from it and am at about 11.5 afr with no difference. I recorded a composite and tooth log but i really don't know what to make of it. Any help would appreciated, thank you.
Re: high rpm miss
Also post MSQ and MSL
Re: high rpm miss
ok current msl and msq
Re: high rpm miss
What kind of "truck coils", the ones that auto-fire early when dwell gets up to about 4.5msec?
Re: high rpm miss
yes the d585, i have tried several dwell settings and a second set of coils without any difference.
Re: high rpm miss
What dwell settings have you tried?
Re: high rpm miss
from 3 to 4.5 ms
Re: high rpm miss
If someone could read or explain what i am looking at on the composite log that would be appreciated, I at am at a loss as to what is causing this, fuel or ignition,, thank you.
Re: high rpm miss
comp log does not show any problems
Re: high rpm miss
thank you very much.
Re: high rpm miss
for your ref if there is a problem with the signal there will be red marks along the bottom of the comp log to indicate sync was lost
Re: high rpm miss
its never had sync issues, just was not sure if it was picking up noise or something, i have put a second set of coils on it as well as plugs, no help,,, guess i will continue to pull fuel and see if it cleans up.
Re: high rpm miss
if you were picking up noise it would cause sync loss, you do appear to get lean spikes in the problem rpm band this could indicate misfires, have you tried tightening the plug gap a bit to see if that helps.
Re: high rpm miss
yes I have them gaped at .025, nkg non resistor and autolite resistor, no difference. I have been cautious on fuel and have taken 15% away so far but still maxing out a 63lbs injector, probably need to lean it further.
Re: high rpm miss
Are you using a pull up resistor on the hall sensor?
