high rpm miss
chilly
high rpm miss
Post by chilly »
I have a High rpm miss/ backfire thru exhaust. Procharged Sbc 14lbs, 60-2 crank wheel with hall sensor and vortec distributor for the cam signal, cnp with truck coils, ms3 pro. Car runs and drives ok, just above 5000 rpm it acts up. I have been pulling fuel away from it and am at about 11.5 afr with no difference. I recorded a composite and tooth log but i really don't know what to make of it. Any help would appreciated, thank you.
billr
Re: high rpm miss
Post by billr »
Also post MSQ and MSL
chilly
Re: high rpm miss
Post by chilly »
ok current msl and msq
billr
Re: high rpm miss
Post by billr »
What kind of "truck coils", the ones that auto-fire early when dwell gets up to about 4.5msec?
chilly
Re: high rpm miss
Post by chilly »
yes the d585, i have tried several dwell settings and a second set of coils without any difference.
nathaninwa
Re: high rpm miss
Post by nathaninwa »
What dwell settings have you tried?
chilly
Re: high rpm miss
Post by chilly »
from 3 to 4.5 ms
chilly
Re: high rpm miss
Post by chilly »
If someone could read or explain what i am looking at on the composite log that would be appreciated, I at am at a loss as to what is causing this, fuel or ignition,, thank you.
grom_e30
Re: high rpm miss
Post by grom_e30 »
comp log does not show any problems
chilly
Re: high rpm miss
Post by chilly »
thank you very much.
grom_e30
Re: high rpm miss
Post by grom_e30 »
for your ref if there is a problem with the signal there will be red marks along the bottom of the comp log to indicate sync was lost
chilly
Re: high rpm miss
Post by chilly »
its never had sync issues, just was not sure if it was picking up noise or something, i have put a second set of coils on it as well as plugs, no help,,, guess i will continue to pull fuel and see if it cleans up.
grom_e30
Re: high rpm miss
Post by grom_e30 »
if you were picking up noise it would cause sync loss, you do appear to get lean spikes in the problem rpm band this could indicate misfires, have you tried tightening the plug gap a bit to see if that helps.
chilly
Re: high rpm miss
Post by chilly »
yes I have them gaped at .025, nkg non resistor and autolite resistor, no difference. I have been cautious on fuel and have taken 15% away so far but still maxing out a 63lbs injector, probably need to lean it further.
darkstar42
Re: high rpm miss
Post by darkstar42 »
Are you using a pull up resistor on the hall sensor?
chilly
Re: high rpm miss
Post by chilly »
yes i am
