going lean
chilly
going lean
Post by chilly »
Can someone explain what is going on here, going way lean, what is telling it to do so? thank you.
slow_hemi6
Re: going lean
Post by slow_hemi6 »
Is it because you are in decell and your VE is about 1/2 to 2/3 what it is at normal idle?
chilly
Re: going lean
Post by chilly »
That seems so obvious,,, Thank you.
billr
Re: going lean
Post by billr »
No "vacuum advance" for the spark, maybe causing misfires that appear as lean.
chilly
Re: going lean
Post by chilly »
I added fuel to the ve table, will try it out tomorrow. This is all very new to me. I added 4 degrees timing and i cleaned up high rpm a little. Every thing I read says there is no way i should be maxed out on a 63lbs injector but can i really pull that much fuel high rpm?
billr
Re: going lean
Post by billr »
I see a duty-cycle approaching 100%, but not while it is lean. The lean only shows during decel. How about pointing to specific times in that most recent log, so I can be sure what you are questioning? Are these 63# injectors, or 60# as shown in the MSQ?
chilly
Re: going lean
Post by chilly »
thank you for catching that, they are 63lbs injectors
