Hello,
I was on the dyno this morning and found an issue with my AFR and PW fluctuating like crazy during full boost WOT. I beleive it is related to my AE settings, as after one hour I noticed the TPS and MAP AE flags flashing while WOT. These flags seem to correspond to my fluctuation.
Can someone take a look at my AE settings?
Below is a quick screen shot of the PW/AFR log. MSQ and Log attached.
1998 Subaru 2.5 RS
22t bottom end
Turbo/16psi
850cc injectors/ Walbro255
E85
MS2 3.0
AFR and PW Fluctuation During WOT Subaru
1998 Subaru 36-2-2-2 Trigger MS2/Extra
Re: AFR and PW Fluctuation During WOT Subaru
Your msq does not work for me i cant open it
Same here - the MSQ appears to be blank inside. Try saving and uploading another copy.
