Looking for a base tune. the setup on the car is
306ci SBF
ported gt40 heads
typhoon intake manifold
b303 cam
on3 air to air intercooler 70mm turbo
bbk throttle body
80# injectors (plan to go e85 in the near future)
Using MS3 Pro
Having problems with the car surging bad at idle and backfiring. not able to drive it at all the way it is.
if someone is willing to send me there base maps that they got there car going with so ill have a starting point. Have a lot to learn with this system.
Thanks in advance
Turbo foxbody Ms3 Pro help
Re: Turbo foxbody Ms3 Pro help
Have you verified all of the fuel and ignition settings are correct first? Post your MSQ for review.
My car is an iron headed 306 with mild trickflow cam, 80lb injectors on e85 with a 72mm turbo so it's very close and I have a good running car currently so I don't mind sharing info with you.
1990 Mustang: MS3Pro Gen 1, 306ci, 72mm turbo, 80lb inj, 36-1 + Cam Sync + D585 coils, World heads, TFS1 cam, GT40 intake, auto, Speed Density
1987 Mustang: MS2v3.57, direct coil control, MSD VR Dizzy, SBE, Weiand 174,190cc heads, F303 cam, TBI w/ (4) 160lb inj, GT500 MAF
