really low ve table
enfini-fc
Re: really low ve table
Post by enfini-fc »
just as a update:
i sent the ecu in under the new TSB
enfini-fc
Post by enfini-fc »
edit "
hopefully this fixes it nope tried somthing will fuel pressure for shits and giggles nope
broke the camshafts in after spending all last year fighting low ve tables and then the injectors lost power, which is another common issue after I turned in a RMA. went to drive it sense the roads are cleared, did not want to start. got it running, yep same thing have to drop tables to 8 just to get it to idle with anything other then 10s AFR. just like before it goes lean for a second then does this. gonna probably have to send it back for repairs. just letting people know its still could happen to them.
beoresettingonground.msq
before pulling from garage, autotune worked.
(285.42 KiB) Downloaded 16 times
Ithinkitbrokeagain.msq
this is backing it out, only way i could make it run.
(285.35 KiB) Downloaded 24 times
