Launch control not working !
martroy
Post by martroy »
I'm trying to use launch control but doesnt seems to work as expected. Heres the situation;
MS 2/Extra and the latest firmware.
I want to use it with ground input. I was looking to make a jumper between JS11 and SPR4 and ground pin 6 to make it work.
Without the jumper, by selecting JS4,5 or 11 in Tunerstudio, launch control active himself like if something is grounding.
What should I look at? Thanks everyone.
Martin
martroy
Re: Launch control not working !
Post by martroy »
I've build low input circuit and have 4,91v on JS5 clutch out and 0v with clutch in. When engine is running, clutch in, clutch out or wire disconnected from Pin 6 makes launch active when RPM and TPS condition are met.
I dont know what should I look at.
Thanks for helping me.
Martin
