Hey everyone! I am having a weird issue where I am losing rpm signal and possibly everything from the ECU on some weird conditions. It seems to happen under acceleration and moderate boost and then cures itself when I back off the throttle. I will attach a datalog and the tune file below. I couldn't seem to capture the event with the composite trigger logger but I havent used it before.
Here is my setup
6 cylinder L28et
MS2/Extra 3.4.0
Chevy coil near plug ignition
Low impedance 440cc supra injectors
Optical crank sensor on DIYautotune 12-1 wheel
I am using the relay board if any of that matters
The event occurs on records 241-243 on the datalog. (The last run where I build up boost)
Thanks for helping me out with this issue!
Loss of RPM signal (Possible Loss of ECU)
Re: Loss of RPM signal (Possible Loss of ECU)
After looking at your log I don't know for sure what caused this glitch.
There is no sync loss recorded but after the glitch it goes back into ASE.
Maybe the controller lost power for a split second which could cause this issue?
I would check all grounds and main power to the controller, other than that I have no idea.
David
David
secL drops to zero so the ecu did reset.
I assume that SecL is seconds live? Is there anything I need to check on the ECU itself?
I will double check the power and grounds to everything. Its so strange because I only have this issue under heavier load. Thanks guys!
This is a bit off topic but is there any way I could peek at your spark map? Or possibly the entire tune? I see that you are running a L28 as well.turbo conversion wrote:After looking at your log I don't know for sure what caused this glitch.
David
Does it do this every time while in boost and only while in boost?
Help your self, not responsible for any damage
David
EDIT: My firmware is different (3.2.5) so some settings are different.
David
