I have a jeep 4.0 boosted with hx35 running a microsquirt. I am running 31lb injectors and ls truck coils in wasted spark with a 36-1 wheel and vr sensor for crank trigger. 8 pounds of boost. I have it running pretty well drivability is great. Only problem is not pulling enough timing under boost. Is there anyone with a boosted 4.0 that would share their timing tables? Just to get some ideas I know each individual engine requires fine tuning.
W Vaughan
Jeep 4.0 timing
Re: Jeep 4.0 timing
David
Re: Jeep 4.0 timing
Current tune and the last data log i believe. I made some adjustments due to my tables not being set up for boost. Havent tried the adjusted tune yet.
Re: Jeep 4.0 timing
What is the static compression?
David
David
Re: Jeep 4.0 timing
Best I can find is 8.8:1.
