Tuning for 85 Vanagon w/EJ202 running rich..
I'm a first timer running microquirt in an 85 Vanagon w/Ej202. Its running well finally but still quite rich and has been causing it flood a couple times over the last few weeks. We have been exaggerating the injector size from 800cc to 970cc to trick it into using less fuel. Helps a bit but not the solution. Anyone see anything that could be the issue?
Re: Tuning for 85 Vanagon w/EJ202 running rich..
Have you tried to adjust the Ve table at all?
In the Ve table, what is with the masive rich area at 85% baro / 1400 rpm? Maybe that's your problem?
Currently Lotus 23C replica Audi 1.8T MS 2 v3 Sequential COP and ignition.
Lotus 7 replica 4age 20V blacktop MS2 v3
What is the actual cc of the injectors and why aren't you using that number?
David
David
