Attached for reference is a JPEG of the stock maximum brake torque and borderline spark tables from my ECU, as well as the default and extrapolated stock table put into TunerStudio.
I wanted to see if everything looked kosher before I start tuning the VE table. I chose to use the stock table because it was comparable to the default table in tunerstudio, and followed the same general trends. This year of mustang uses load calculated from MAF air charge. I got the car started and worked on the idle to 2000 rpm area of the VE table last night, I want to go and drive it to get some more of the map filled in, but honestly spark related stuff scares me. All of the checks are done, timing was spot on with a timing light, all my signals look good except my TPS which bounces 2-3% when the car is running (I need to get shielded wiring, the coil packs are really close to the wiring). Currently using a custom BIP373 spark box, full sequential with MS3X, 47lb EV6 injectors, idling beautifully. The car worked reasonably well on the stock ECU with a quarterhorse piggyback up to a few trials 12lbs of boost, usual was 7lbs. There were some fuel shutdown issues that I couldn't resolve so I decided to go MS.
My questions:
- Is it ok to assume that MAF load from the stock tune is equivalent to the kPA load from tuner studio? Load is unitless isn't it (kPa current/kPa @ max * 100, or MAF current/MAF @ max).
- Do the values look acceptable? The car is a 2V modular V8, 9.8:1 compression, stock internals (hypereutectic pistons, hence my fear of aggressive spark & detonation). The car will be seeing 5-7lbs of boost until I work on the internal engine.
- If a number is closer to 0, it is retarded correct, which is a safer place to be? If the number in the borderline spark table (values are advance) is less than my maximum break torque value in the same area, how should I deal with it?
