Launch Control TIMING RETARD
IS THE LAUNCH CONTROL TIMING RETARD LOGGED AND SHOWS THE RETARDED DEGREES?
Example if is i use -15 degrees in the picture will i see -15 in the log?
see settings in photo and attached log.
i cant seem to build boost.
Re: Launch Control TIMING RETARD
Yes you will see it. Attatch a datalog
data log is attached above. its not retarding
Your log shows it working at -15*. Open the SPK: spark advance
i see now, its in spark: launch.
thanks
thanks
I have a question that pertains to this launch timing issue. if you set the figure to -15 is that what you are leaving on when you let go of the button, and if so? wouldn't you want it a bit higher??? I'm just asking, I'm not telling, thanks
82 Mustang 400+ cu in. with a fogger system. Hurting feelings.......
When you release the button it will go straight to the timing you have in your timing table at that load and RPM.
If you have "Timed Retard after Launch" enabled, it enables a seperate table for you to adjust how quickly you can ramp your timing back in after the button release.
Yep, and I use launch timing retard to manage the first 60 foot based on current track condition. This is why I look at the Spark advance, it tells the whole story in one graph instead of having multiple timing windows open
Side note, if you have vss you can see how well your reacts. I have suspension sensors too and it's neat too see launch control release, suspension move and then vss move. My cars reaction time is just about .200 so I'm learning to bump in a just bit deeper to help dual my reaction time
ok, great. that's the info I'm looking for.
nathaninwa wrote:Yep, and I use launch timing retard to manage the first 60 foot based on current track condition. This is why I look at the Spark advance, it tells the whole story in one graph instead of having multiple timing windows open
What is the best suggested way to get a timing retard after launch set up to maximize traction??
per gear timing retard after launch is that possible?
You can use a time based timing retard or blend between two spark tables based on gear.chris_brathwaite wrote:per gear timing retard after launch is that possible?
Can this be done on a MS2 v3.57? I do not see this option available anywhere. Thanksjesse408 wrote:When you release the button it will go straight to the timing you have in your timing table at that load and RPM.
These are all MS3 features.rdclark123 wrote:Can this be done on a MS2 v3.57? I do not see this option available anywhere. Thanks
