Hey Dennis
My plan is to run 1.1 bar of Boost.
I purchased the EBC kit from DIYAutotune. It has a frequency from 19hz to 39 hz. Hope to get it installed this weekend.
Thanks for explanation on EBC and VSS.
I also have some work to do on the VSS.
I have the knock sensor installed next to chimney at centre rear of motor. I do not have it turn on.
Do you have a shift light installed?
MS3 Pro Pulsewidth drops to zero under load
Re: MS3 Pro Pulsewidth drops to zero under load
John,
No, I do not have a shift light installed.
I attached my msq below. I have not gone to 1.5 yet as I need to figure out engine states and go through some logs to come up with appropriate numbers for the states.
Porsche 930 3.0 Slantnose
Thanks Dennis
