What is the benefit of running Shadow dash on Android vs Tunerstudio on windows tab?
Seems like TS can do everything Shadowdash can plus much more.
I would like to run the autotune from my tablet as well.
Windows Tab with TS vs Android with Shadow dash
Re: Windows Tab with TS vs Android with Shadow dash
Windows takes longer to start-up and then you have to select what you would like to do such as gauge display. Generally, only one view is allowed unless you re-load another.
Shadow dash is more automated and can start when device is powered plus has multiple screens by swipping through them. Especially useful in car when loaded onto a HU so there isn't another device such as tablet or laptop bouncing around on spare seat. Another benefit which I haven't started to use is to automatically upload your datalog to a user file when connected to Wifi. This allows the driver to view files on-line without spending time to copy and paste then opening through portable device such as USB.
jim
jim
Toyota MR2 98 3sgte
MSPNP2 with 3.57 mainboard
TD05SL2-18g with external WG
HKS EBC running 17psi boost.
