FTDI Driver
FTDI Driver
Seems like eveytime I get an update to Windows 10, I have to reload the FTDI-D2xx drivers for Tuner Studio. Is this typical, something I can do to fix?
Re: FTDI Driver
I am using windows 10 and have been through numerous updates without any issues.
David
David
Re: FTDI Driver
I wonder if it Norton, or Java, or another support application upgrade is rejecting it? Not sure what the "whole" suite of SW and versions are needed.
Re: FTDI Driver
I also have Norton.
Wish I could help but I haven't a clue.
David
David
Re: FTDI Driver
I would post this question in the "Tuner Studio" category to see if Phil can help you out.
Porsche 930 3.0 Slantnose
