How PW1 and PW2 could be different?
When I was at WOT with my car, it looks like it missed but very fast. When I was looking datalog, it appears PW1 went to 0 but I didnt hit rev limiter or Something like that. What could make this happens and why when reviewing a datalog, PW1 and PW2 could be different that much? I'm not using EGO correction.
Re: How PW1 and PW2 could be different?
David
Cant join a datalog, its big like 13mo.
Thanks.
Thanks.
Try trimming it.martroy wrote:Cant join a datalog, its big like 13mo.
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
I've found how to trim it.
Here's the log. thanks guys for helping me out.
OK, now post the MSQ...
Here we go.
Is this, perhaps, related to the problem reported here?
http://www.msextra.com/forums/viewtopic ... 31&t=66098
Hi billr, thanks for the fast answer and information you gave me. I dont think its related as I have a MS2 3,57 and the real concern is: How PW1 went to a pulse of 0 when not PW2 and no rev limiter active at that moment ??? In other datalogs, I've seen a good difference between PW1 and PW2 during a steady load witch should be close each other in a "2 squirts / alternating mode".billr wrote:Is this, perhaps, related to the problem reported here?
Hi
Your Differenz in PW1 vs PW2 are OK!
For safety: Open Different Bank Setting in Injector Dead Time and make the same Setting with Bank1!
Your PW1 to 0: Load the FW new and Test it.
Frank
Frank
Hi Frank, look at 368,095, you will see PW2 is lower than PW1, for me, its anormal.franksidebike wrote:Hi
Frank
I will do what you recommanded, and reload the firmware and give some test. I'll report back today.
Want a guess? Try turning off the "launch control". That is the only thing I see that has some kind of threshold right at 4000 rpm. I'm thinking that if your input for flat-shift is flaky it could be triggering when not intended.
Lets say you're right. If thats the case, why I see a solid 1023 on ADC7, status1 to 9 and status2 and status3 to 0 while PW1 went to 0?billr wrote:Want a guess? Try turning off the "launch control". That is the only thing I see that has some kind of threshold right at 4000 rpm. I'm thinking that if your input for flat-shift is flaky it could be triggering when not intended.
As requested, I did my homework and did what you guys asked.
Reloaded firmware
Put same deadtime for bank1 and bank2
I did change flat s*** limiter to 1500 RPM to see during normal road testing, if I will get the issue. I'm in the process of reviewing all logs but heres new MSQ and MSL with the issue happens on both banks !!!
Reloaded firmware
Still just guessing, of course, but I would turn that "launch" completely off; make sure it is out of the picture.
With "Basic Trigger" it is possible that a noise pulse came in generating a false high RPM which tripped the rev limiter briefly. With the relatively slow speed of datalogs (compared to the engine) you won't always capture that.
Hi James, what do suggest me to fix that issue? Tomorrow, I will disable launch/flat shift to test if it still there.jsmcortina wrote:With "Basic Trigger" it is possible that a noise pulse came in generating a false high RPM which tripped the rev limiter briefly. With the relatively slow speed of datalogs (compared to the engine) you won't always capture that.
If that is the rev-limiter engaging, I wonder why we don't see the spark retarding along with the fuel cut?
Try turning off the rev-limiter, see if that eliminates the problem. (Just as a "diagnostic test", not permanent solution).
Is your "basic trigger" mechanical points, or some kind of electronic switch?
Ford TFI distributor.
As "stats" how many time I get the issue, on 8 WOT pull, I got the problem 2 times.
Today, I remove the fuel cut for revlimiter but keep spark cut and disable completely Launch/Flatshift option. I did 6 WOT pull and none gave me the issue. In the next days, will continue to run the car hard to try to make it happens. If the Launch/Flatshift was trigger, I dont understand with ADC7 remains to 1023 like if the input remains to the same voltage (5V) !!!
