installed table switching hardware and now lean off throttle
Postby turbothis » Sat Sep 09, 2017 3:23 pm
i got the table switching working fine it seems by the way it runs and the dashboard icon lights up on msdroid saying it is switched
now i have a strange very lean spot when off throttle or just at the lightest cruise
i will get a picture of the wiring soon
trying to add my msdroid tune for review
main.msq
(38.94 KiB) Downloaded 9 times
1978 ford courier baja truck
2000 3.0L dohc duratec V6
supercharger m90 3" pulley making 13#
6x 35lb injectors E85
ms1 v2.2 running 029y4
tuner studio MS v2.6.19
turbothis
Re: installed table switching hardware and now lean off thro
Postby turbothis » Sat Sep 09, 2017 5:06 pm
not sure if drop box got the right one
this is for sure though....
dual tables.msq
(47.03 KiB) Downloaded 5 times
turbothis
Postby turbothis » Sat Sep 09, 2017 6:58 pm
is there a way to attach the cranking and start enrichment stuff with the fuel and spark tables?
turbothis
Postby ChevelleFan » Sat Sep 09, 2017 10:33 pm
turbothis wrote:i got the table switching working fine it seems by the way it runs and the dashboard icon lights up on msdroid saying it is switched
If I'm understanding, you;re saying you have a lean spot when table-switched? For the fact that both VE1 and VE3 are largely the same, compare from 500-2200 rpm, up to 50kpa. VE3 is a bit leaner there than VE1.
-Dave
'70 Chevelle zz383/700r4/3.55 MS2-Extra, Holley Stealthram, 12.18 @ 109
'92 Saturn 1.9 DOHC/5sp, MS2-Extra
ChevelleFan
Postby turbothis » Sun Sep 10, 2017 7:51 am
since i started the table switch i have only ran ve1 which is my E85 tune
it was nasty great before table switching
power side is still solid but has a crazy lean cruise and slightly under throtttle setting
i will get a log of this today and after that unwire it to see if it goes away.....
thanks for the reply
turbothis
Postby turbothis » Sun Sep 10, 2017 11:47 am
ok here is a log of the lean ness
i turned off the fuel and spark table switching and the lean is the same
next i will unsolder the leads inside the box to see if that is the issue
for reference V1 is E85 and VE3 is super unleaded
now.msl
(261.61 KiB) Downloaded 8 times
turbothis
Postby turbothis » Sun Sep 10, 2017 12:09 pm
maybe my wiring is bad?
5v from led17 resistor (black wire)
diodes are oriented correctly i think (both black wires are the switch)
0v from db9 pin 9 i believe
turbothis
Postby turbothis » Sun Sep 10, 2017 12:35 pm
man, i removed the table switch hardware and it remains a lean phantom
i swear it was not like this before i wired in the parts
i guess i will load the original 1 table E85 tune ( i swear was good) and see about tuning out the lean phantom if it is in there too?
turbothis
Postby turbothis » Sun Sep 10, 2017 2:50 pm
-Dave
glad you mentioned that!
i did some initial autotuning with tunerstudios on my laptop (WIN7)
then i watch the gauges of things on my tablet (android)
somewhere in there the load tune or update controller or one of the super fancy options i choice poorly or something
now i can solder up the table switch stuff again and just continue the tuning
sorry for the waste and thanks for the help
turbothis
Return to Tuning
Users browsing this forum: Bing [Bot] and 2 guests
