i have been reading posts for a while now and it is starting to sink in, but im not sure if my fuelling is the cause of my engine not pulling on full throttle,
I would really appreciate some feedback on my data log, just to see if i am somewhere near where i should be.
Thanks in advance
engine not pulling as it should
- Attachments
- 2017-09-19_18.17.00.msl
- (1.03 MiB) Downloaded 33 times
Re: engine not pulling as it should
Your MAP sensor is reading a constant 100, fix that.
Graduate of EFI University.
At full throttle and accelerating, your AFR is between high 13s to low 14s - I'd say too weak.
Thanks for the replies,
I should have said its a 2.0 zetec engine with individual throttle bodies, with no map sensor.
Do you think the whole map could do with more fuel, say 5-10% more, or just full throttle? from what ive read these engine like to run slightly rich but i could be wrong...
Cheers
Cheers
That's at least six degrees more timing at full throttle than what the last Zetec we tuned wanted.
Posting the MSQ could still help.
