ignition table
joaocaleira
ignition table
Post by joaocaleira »
So i started with tuning the ignition table of the GX31, How should i proceed to increase the power and torque of the engine? Basically it seems like the more the advance the more torque, almost in the limit of detonation. But i also know that its not always that limit that is the most optimized point. So this engine as a standard ignition advance of 27 degrees, and i was generating a initial spark advance table on the web and it gives me values way bellow the 27 degrees. Does it make sense to use them? or it doesnt make sense to put values on the table bellow 27 degrees?
Regards
Re: ignition table
Empirically.
Put it on an engine dyno and see where it makes the most torque.
tryingbe
Re: ignition table
Post by tryingbe »
Is it a Honda GX31 engine?
1985 Dodge Omni GLH Turbo MicroSquirted 367whp http://www.msextra.com/forums/viewtopic ... 04&t=67324
joaocaleira
Re: ignition table
tryingbe wrote:Is it a Honda GX31 engine?
Yes it is. Before with the magnet ignition it went until 5800 rpm, with full throttle. Now with the electronic ignition doesnt even exceed the 4200 rpm.
spitnl
Re: ignition table
Post by spitnl »
27 degrees fixed timing does look like a lot to me for such a small engine.
I would check the timing with the magneto at various rpms.
Use those timings to make a base table.
If that's not possible I would use the ignition timing generator values.
tryingbe
Re: ignition table
Post by tryingbe »
:msq:
tryingbe
Re: ignition table
Post by tryingbe »
spitnl wrote:27 degrees fixed timing does look like a lot to me for such a small engine.
Considering idle speed is 3,100 +/- 200 rpm, not really. This engine only puts out 1hp.
http://cdn.powerequipment.honda.com/eng ... zm3613.pdf
tryingbe
Re: ignition table
Post by tryingbe »
joaocaleira wrote:i was generating a initial spark advance table on the web and it gives me values way bellow the 27 degrees. Does it make sense to use them? or it doesnt make sense to put values on the table bellow 27 degrees?
What did you use to generate the table? URL?
This give at least 10 degree more than 27 degree for spark. http://www.useasydocs.com/theory/spktable.htm but it is mainly used for engines with much bigger displacement.
How is the a/f ratio monitored?
How is the knock monitored?
