Just made my first log and I'm seeing spikes in the Coolant Temperature Sensor.
The spikes don't max out(+3degC), are only positive and seem to increase in frequency with rpm.
Is this something I need to worry about and correct?
If so, what would be a likely culprit; failing sensor, wiring or interference?
Fred
spikes in CLT
spikes in CLT
- Attachments
- 2017-10-24_18.12.52.msl
- (636.27 KiB) Downloaded 29 times
- 2017-10-25_18.08.26.msq
- (119.23 KiB) Downloaded 27 times
Re: spikes in CLT
A 3 degree spike is not going to have any significant changes, and at the top of the sensor range this is well within common electrical noise. I wouldn't worry about it.
Re: spikes in CLT
OK, thanks Matt.
Re: spikes in CLT
You should check inside the megasquirt case for Bruce Bowling striking a baby with a stick.
It's your fault.
Sent from my MI 5 using Tapatalk
It's your fault.
