Flood Clear TPS questions
martroy
Post by martroy »
I'm looking a way to "bypass" priming pulse to avoid flooding engine while turning on and off several time the ignition. The way I understand and read the feature, it says:
"Above this throttle position no fuel will be injected during cranking to help clear a flood situation. It will also disable priming".
So that what I did, push TPS to 100% and turn on ignition key after while holding TPS and surprise, priming pulse went throught. What I missunderstood? Here's a log.
Second question is. When priming pulse is set to 4.9 PW in the graph at that temperature, what control the duration ? In my log, It's almost 2 seconds.
Thanks guys.
Martin
2017-10-25_17.47.12-flood.msl
(63.95 KiB) Downloaded 29 times
Blown88GT
Re: Flood Clear TPS questions
Post by Blown88GT »
martroy wrote:...I'm looking a way to "bypass" priming pulse to avoid flooding engine while turning on and off several time the ignition....
Injectors stay closed when you do this. You cannot flood the engine when cycling ignition on & off.
billr
Post by billr »
As you discovered, the "flood clear" TPS setting has no effect on the key-on priming pulse. Set the priming pulse to 0, that will prevent it from happening. It also prevents the fuel pump from turning on for a couple of seconds at key-on; but I have found that to be no big deal, my FP goes from 0 to 44 psi in 7/10 of a second from the time crank rotation is detected. Plenty fast enough for me...
martroy
Post by martroy »
billr wrote:As you discovered, the "flood clear" TPS setting has no effect on the key-on priming pulse. Set the priming pulse to 0, that will prevent it from happening. It also prevents the fuel pump from turning on for a couple of seconds at key-on; but I have found that to be no big deal, my FP goes from 0 to 44 psi in 7/10 of a second from the time crank rotation is detected. Plenty fast enough for me...
Understood that but would like to use priming pulse to help fast starting but would like to bypass priming pulse in the event of cycling key on, key off.
I'm tuning the priming pulse because was set to 0,1 before to avoid that.
The strange thing is description says its disabling priming pulse too.
Still have no explanation about duration of the pulse in the log.
Thanks billr
Post by jsmcortina »
martroy wrote:The strange thing is description says its disabling priming pulse too.
That's because that how it works.
martroy
Post by martroy »
jsmcortina wrote: That's because that how it works.
Hey James, not sure to understand your comment. I was saying earlier that "Flood clear option" dont disabled injectors priming pulse while turning ignition on and holding TPS over the defined value. As the description written in Tunerstudio, it should but its not happening.
Martin
Dennis_Zx7r
Post by Dennis_Zx7r »
I noticed flood clear not working at all for me about a year ago on MS2Extra (http://www.msextra.com/forums/viewtopic ... it=priming). Haven't checked on MS3 so far, but on MS2 neither the priming pulse nor the injections during cranking were disabled.
My project: Link
grom_e30
Post by grom_e30 »
martroy
Post by martroy »
Ouch, so is there any ways to fix that issue ?
martroy
Post by martroy »
No one ?
That's how MS2 behaves.
The skip-priming is an MS3 feature.
martroy
Post by martroy »
jsmcortina wrote:That's how MS2 behaves.
The description in that option in Tunerstudio should be changed than because its saying it should work.
Some says its not disabling cranking pulse too, why?
DaveEFI
Post by DaveEFI »
martroy wrote:Hi,
Thanks guys.
Martin
Surely a priming pulse of 2 seconds would flood the engine? it's more like 12 Msec max here. The purpose being to eject any 'air' from the fuel rail. The fuel pump will run for a couple of seconds at switch on - but with the injectors closed.
Dennis_Zx7r
martroy wrote:[...]Some says its not disabling cranking pulse too, why?
I did say that. I remember that fuel was still injected and I could start the engine with TPS well above flood clear (looking into the ITBs and seeing the fuel getting injected). But as I know memories can easily be wrong and have no opportunity the check it again (no MS2 anymore) I don't want to insist on this. Or maybe the priming was enough to get the engine above cranking rpm. I have no logs from this, as this was 19? months ago when I started with MS and was just trying to get the engine to run.
My project: Link
martroy
Post by martroy »
In my log, the duration of a pulse of 5ms is 2 seconds.
That's the way it shows in the datalog, but it doesn't mean the pulse is 2 seconds long.
It means that the value of the variable "PW" was 5ms for all of that period, however, there was only one injection lasting 5ms.
