MAP swings at high rpm, what can i do.
martin2day
Post by martin2day »
Hello,
my engine is a small block chevy 350 with a composite manifold from AFR.
With 5000rpm and more the map begin to swing.
Today i drive Alpha-N with the option Multiply MAP so intact of this my PW is also swinging.
At 5000rpm and more i see change in PW from 5% and more. (swing)
Please see the short LOG.
modified.msl
(80.47 KiB) Downloaded 38 times
My MAP Averaging Lag Factor is set to 25.
What do you think is the better solution for my performence car and motor?
1. lower the Lag Factor... but than the MAP is slower as the TPS change (slow response time)
2. Change to pure Alpha-N
3. Let the PW swing
Thank you very much for helping.
Regards Martin
billr
Re: MAP swings at high rpm, what can i do.
Post by billr »
Can you give more detail on the manifold, maybe post pictures?
martin2day
This is the manifold.
All 8 intakes are connected to 1 plenum. The source of the map signal is also connected there.
You see this little black pipe right.
Martin
elutionsdesign
Post by elutionsdesign »
If you plot PW vs. MAP in megalogviewer you have a perfect 45 degree line, no reason to change to alpha-N. I wouldn't lower MAP averaging either, probably already too low. There isn't much swing in that log, maybe 1 KPa out of 75 which wouldn't bother me unless you notice issues. Your AFR is pretty constant in the 13's, maybe try lowering that a bit?
Graduate of EFI University.
billr
Post by billr »
That was kind of my impression, too, the swings are really only +/- 1 to 2%; not enough to be much problem considering other compromises with a typical V8 head.
spitnl
Post by spitnl »
Are you running staged injection?
Hope you are, because in this log with less than 50% TPS the injectors are already over 85% Duty cycle.
Also how many primary injectors?
martin2day
Hello,
please also have a look at the PW. Here i see up to 5% different from step to step.
Yes i run staged injection. It is a TBI Setup. Up to 49% i drive only with the front 2 throttle blades and the 2 fron injectors.
Over 49% TPS the rear blades begin to open and the rear 2 injectors cum in.
Martin
billr
Post by billr »
5% peak-to-peak, but that is only +/-2.5% deviation from "perfection".
spitnl
Post by spitnl »
Hi Martin,
Had another thought about your issue.
Was this log made with or without EGO correction on?
You didn't post an msq, but I had a look an earlier one you posted and one thing caught my eye.
In the "EGO Control" menu, you had set the "ignition events per step" set to 8.
This is very low for an 8 cylinder and could cause the AFR swings you're seeing.
For an 8 cylinder the recommendation is to set this to at 33.
So I would try 33 and test if you're still seeing those swings.
Fred
martin2day
Good afternoon,
no, my EGO is deactivated. I set the rpm active to 8000rpm.
Today i think i find the solution.
My map is swing a little bit. So the "normal" PW is think also a little bit.
But please have a look at the EAE... my setup is to high... so the EAE multiply the little PW noise to big noise.
I set the ear_AWC is set to about 80% in that area.
I want the EAE to react very quick...
I think i have to lower the value and then the noise is gone.
Thanks for helping.
Martin
kjones6039
Post by kjones6039 »
martin2day wrote:Up to 49% i drive only with the front 2 throttle blades and the 2 fron injectors.
Seems to be a bit odd to an old school guy. How in the world do you keep from starving the other 2 cylinders??
Or did I not understand your post? Which is more than likely! lol
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
martin2day
Hello Ken,
sorry, but i don't understand what you mean.
Can you say it in other word's... my english is not so good.
Martin
whittlebeast
Post by whittlebeast »
You could always try ITB Mode. I would think it would improve the situation that you are looking at.
See https://www.youtube.com/watch?v=_GDZxUVTplk
Andy
martin2day
Andy,
thank you for your hint.
But if i use ITB i must shut off "multiply map" to have pure Alpha-N at WOT?
If multi Map is on i have the same situation as now, or?
Martin
whittlebeast
Try it, it is free.
Use multiply MAP.
Andy
kjones6039
martin2day wrote:Hello Ken,
Martin
You are running independent throttle bodies, correct? If you shut off 2 injectors you are running on 2 cylinders, correct? Won't the other cylinders starve for fuel?
Your English is fine. I think I don't always ask my questions properly!
whittlebeast
I think you are over thinking this.... Just try ITB Mode. Use Ignition Cut for rev limiting. Get a log and post it up.
Your Fuel pressure concerns me more than the PW.
Andy
martin2day
Hello Ken,
thank you for your answer.
No i don't drive independent throttle bodies. I "only" have got a TBI.
I use my "old" MSD Atomic EFI body Image and connect the MSQ. :-)
I also rework the throttle cable. Original the front and rear blades open at the same time, but now only the front open up to 48%TPS.
Martin
martin2day
Andy,
I connect the original MSD Fuel pressure sender. I do not use shielded cable. I only what to have a approx value to adjust my fuel pressure.
I think you mean the swing of the signal, or do what concerns you?
I think you are right... i over thinking this. That's my big problem. :-)
Martin
kjones6039
Got it!
I do something similar with my Holley TBI. Except I use staged injection combined with table switching.
