Dead time. Something seems wrong
Postby maych87 » Thu Nov 30, 2017 1:06 pm
Hi
I noticed today that my actual dead time seems off. I have my car set up sequential injection and my dead time is set at .765 @ 13.2 volts. i Am using curve 1 so from the way i read it the higher the voltage the smaller the dead time should be. My car is fairly steady around 13.6 to 13.8v so i expect a dead time of less than .765. At 13.6 v I am getting a dead time of 1.039 which is higher than my dead time at 13.2v. I am reading that from the fuel calculation summary gauges under fuel settings. Is there something that I am misinterpreting or is there a problem somewhere. Attached is my msq
2017-11-28_14.43.08.msl
datalog
(160.55 KiB) Downloaded 9 times
2017-11-27_11.45.59 set up over run fuel cut.msq
msq
(287.57 KiB) Downloaded 9 times
maych87
Re: Dead time. Something seems wrong
Postby tryingbe » Thu Nov 30, 2017 3:10 pm
Why is your coolant temperature at 249F?
tryingbe
Postby maych87 » Thu Nov 30, 2017 3:22 pm
Air cooled porsche that’s a cylinder head temp. That’s normal.
Sent from my iPhone using Tapatalk Pro
maych87
Postby Blown88GT » Sat Dec 02, 2017 6:35 pm
MS3 firmware has a bug.
viewtopic.php?f=131&t=66098
1988 Mustang GT, 57k miles, Orig. Owner
ProCharger 600B I/C, 12psi, FRPP Hdrs, Flwmstr F2, 3G Alt, Mk8 Fan & DCC, 3.55's, Prog Sprng, Subfrms, UCA, LCA, FCA, Tokico 5-way, CSA 16x8, Bridgestone RE760 225/50R16, Crane HI-6, Kirban FPR, MS2, DIYPNPF60, LC2, C&L76mm blo-thru MAF, 30lb FRPP
Blown88GT
Postby jsmcortina » Sat Dec 02, 2017 7:24 pm
Had.
Return to Tuning
