Knock sensing setup of MicroSquirt
Postby superspeedy » Fri Dec 08, 2017 2:47 am
Guys
I am new on MS tuning things. We got some issues on knock sensor setup on MicroSquirt.
Does MicroSquirt have knock control functions? If so, we really got the issues as below.
My MS is for LS1 24x setup from EFI Source.
We have a knock monitor with 0-5v signal output to MicroSquirt. We tried connecting knock signal to Pin5 SADC/MAF and Pin29 SADC, it seems like nothing wrong with wiring.
We have tried setting knock sensing type of both On/Off and Analogue and each Input Pin. But we got nothing on the real time gauge.
Anyone has such experience on MicroSquirt, please?
Thank you so much!
superspeedy
Re: Knock sensing setup of MicroSquirt
Postby tryingbe » Fri Dec 08, 2017 1:04 pm
What knock module/knock monitor are you using?
0-5v digital signal or 0-5v analogue signal?
I'm using lilknockmeter and Microsquirt, knock detection works fine here.
tryingbe
Postby superspeedy » Sun Dec 10, 2017 9:16 am
tryingbe wrote:What knock module/knock monitor are you using?
I use HKS A/F Knock module, it is 0-5v analogue signal.
superspeedy
Postby tryingbe » Mon Dec 11, 2017 9:16 am
I would start by setting the the knock module its most sensitive settings then see if Microsquirt can pick up signal from the module.
https://1jzmerc.com/files/hks-faq/hks-a ... uction.pdf
tryingbe
Postby superspeedy » Fri Dec 15, 2017 12:32 am
tryingbe wrote:I would start by setting the the knock module its most sensitive settings then see if Microsquirt can pick up signal from the module.
Yes, I did. But still same. There was singal from AFK, but MS didn't show anything.
superspeedy
Postby tryingbe » Fri Dec 15, 2017 7:56 am
Not sure what to tell you, 0-5v analogue knock input works fine here with my Microsquirt with the 3.4.2 firmware.
tryingbe
Return to Tuning
Users browsing this forum: Google [Bot] and 1 guest
