Can I use a Thermocouple for coolant temperture?
Postby frontrangeFJ40 » Tue Dec 19, 2017 12:21 pm
I would really like to use the same input for both a instrument cluster gauge as well as the ECM. I have a K type thermocouple for the dash gauge, so can I use the conditioned and linear T/C amplifier output to feed into a spare 0-5 volt input and reassign the gauge to use this for the CTS reading?
TIA
frontrangeFJ40
Re: Can I use a Thermocouple for coolant temperture?
Postby billr » Tue Dec 19, 2017 12:37 pm
I don't think it is reasonably possible because the CLT and MAT cal curves have to be the same. Maybe that can be handled with different LUTs in the .ini files, but I don't think so.
I am pretty certain this isn't worth the bother, even if it can be done. GM-type sensors can be bought for under $10, and as small as 1/8" NPT; so easy to locate almost anywhere. Look for a Standard Motor Products TX-73, for example.
billr
Postby frontrangeFJ40 » Tue Dec 19, 2017 12:52 pm
Is that really true when Tuner Studio has separate calibration tools for each sensor?
The problem I've been fighting is having two different readings that can be off by 20F or more. Right now I'm using thermistors for both and I never know which to trust until I get out an IR gun and check actual head temperature. I've come to the conclusion that I hate thermistors and their non-linear & less than completely predictable response curves.
frontrangeFJ40
Postby jsmcortina » Tue Dec 19, 2017 1:06 pm
billr wrote:I don't think it is reasonably possible because the CLT and MAT cal curves have to be the same.
Nope. There are two different calibration lookup curves.
The only difficulty is that the lookup curve generator in TunerStudio is designed for thermistors and generates a curve. For a thermocouple you would need to hand generate a linear transform and import that file.
Postby frontrangeFJ40 » Wed Dec 20, 2017 11:25 am
I looked for the correct table (there's an awful lot of tables in there...) and wasn't able to find the one I'm looking for. Any clue what it might be called, even a partial name I could do a string search on?
frontrangeFJ40
Postby Blown88GT » Wed Dec 20, 2017 5:30 pm
frontrangeFJ40 wrote:I...The problem I've been fighting is having two different readings that can be off by 20F or more. Right now I'm using thermistors for both and I never know which to trust until I get out an IR gun and check actual head temperature. I've come to the conclusion that I hate thermistors and their non-linear & less than completely predictable response curves.
You want something accurate? Use an RTD. The tradeoffs are a lower response time & greater expense.
RTDs rely on certain metals' (usually platinum, nickel, or copper) thermo-resistive behavior to detect changes in temperature. RTDs respond to temperature changes very linearly and can achieve good accuracy.
A thermistor is a temperature-sensitive resistor, whilst a thermocouple generates a voltage proportional to the temperature.
Resistance Temperature Detectors (RTDs) are sensors that measure temperature by correlating the resistance of the RTD element with temperature. Most RTD elements consist of a length of fine coiled wire wrapped around a ceramic or glass core.
https://cecas.clemson.edu/cvel/auto/sen ... ature.html
1988 Mustang GT, 57k miles, Orig. Owner
ProCharger 600B I/C, 12psi, FRPP Hdrs, Flwmstr F2, 3G Alt, Mk8 Fan & DCC, 3.55's, Prog Sprng, Subfrms, UCA, LCA, FCA, Tokico 5-way, CSA 16x8, Bridgestone RE760 225/50R16, Crane HI-6, Kirban FPR, MS2, DIYPNPF60, LC2, C&L76mm blo-thru MAF, 30lb FRPP
Blown88GT
Postby frontrangeFJ40 » Wed Dec 20, 2017 6:25 pm
Thanks, but I started my professional life as an EE and I'm pretty familiar with the technology.
frontrangeFJ40
Postby Matt Cramer » Thu Dec 21, 2017 6:51 am
frontrangeFJ40 wrote:I looked for the correct table (there's an awful lot of tables in there...) and wasn't able to find the one I'm looking for. Any clue what it might be called, even a partial name I could do a string search on?
You would need to go to Tools -> Calibrate Thermistor Tables. There's a button there for uploading custom INC files.
Postby frontrangeFJ40 » Thu Dec 21, 2017 6:55 am
FANTASTIC!!
Any idea where I can find an example of how that file should be formatted??
frontrangeFJ40
Postby elaw » Thu Dec 21, 2017 9:22 am
If you look in the "inc" subfolder of the folder you have TS installed in, there's a file called "thermfactor.inc" that I think is in the right format. But I'm not sure what the numbers in it mean... I think there are 256 entries representing A-D values, but the actual numbers in the file I'm looking at are kind of weird.
Eric Law
elaw
Postby jsmcortina » Thu Dec 21, 2017 9:34 am
I'm not actually sure of the format that TunerStudio expects, best to ask in that sub-forum.
Inside the firmware, the table has 1024 entries for MS2/3, these correspond to ADC count. ADCcount = Volts/5.0 * 1023. The temperature is in degrees Fahrenheit, * 10.
Postby frontrangeFJ40 » Thu Dec 21, 2017 10:00 am
Thanks guys!
frontrangeFJ40
Return to Tuning
