tuning knock sensor with high octane fuel
Postby Yves » Wed Dec 27, 2017 6:04 am
Anyone here ever try to tune their knock sensors with high octane fuel ? If so, what were the results.
Yves
Re: tuning knock sensor with high octane fuel
Postby billr » Wed Dec 27, 2017 9:28 am
You better define what you mean by "high octane". Is that 100 octane, or something more like 115/145 avgas? How is the octane level boosted, using TEL, lots of alcohol, something else?
billr
Postby tryingbe » Wed Dec 27, 2017 10:54 am
Even though I've done tuning via reading the knock sensor, dyno tune is the best, you can see the result on the graph and don't have to worry about speed limits, driving, road condition, or traffic.
tryingbe
Postby Yves » Wed Dec 27, 2017 10:57 am
Sunoco and it's an alcohol blend as far as I know. 110 MON.
Yves
Postby KaPower » Sun Jan 07, 2018 1:56 pm
If you mean setting up your knock threshold and other various knock system settings, then yes. I've tried the retarded ignition map by -10* degrees with 92 octane, and the retarded ignition map by -5* with a full can of Torco octane booster and 92 octane. Both methods are similar according to my logs, but the torco method is my favorite so far. I used scatter plots to identify the normal engine noise levels.
KaPower
Postby Yves » Sun Jan 07, 2018 2:31 pm
KaPower wrote:If you mean setting up your knock threshold and other various knock system settings, then yes. I've tried the retarded ignition map by -10* degrees with 92 octane, and the retarded ignition map by -5* with a full can of Torco octane booster and 92 octane. Both methods are similar according to my logs, but the torco method is my favorite so far. I used scatter plots to identify the normal engine noise levels.
What scatter plot did you use ?
Yves
Postby KaPower » Sun Jan 07, 2018 4:35 pm
My Favorite is RPM/Knock-in/Knock-in & also RPM/Map/Knock-in
Knock Scatter Plot.png (228.23 KiB) Viewed 239 times
KaPower
Postby KaPower » Sun Jan 07, 2018 4:43 pm
Haven't been able to make much use out of the table generator other than looking at individual cylinders to setup the gain based off load and rpm (instead of the single rpm vs noise table that we currently have) The interesting thing to note is how useful a load vs RPM table would be for setting knock input noise thresholds.
Knock Input Table 16x16.png (266.28 KiB) Viewed 237 times
KaPower
Postby Yves » Mon Jan 08, 2018 12:03 am
How much octane did the booster provide. I hear they don't do all that much. Was contemplating on mixing toluene into the fuel as seemingly Sunoco stopped their supply of race fuel here.
Yves
Postby KaPower » Mon Jan 08, 2018 4:26 pm
Torco is the real deal. Most octane boosters advertise in points that equal .1 so 92 would become 92.4 with 4 added points. Torco actually added several points extra depending on the mix ratio. My knock sensor went dead quiet with Torco added to the system, and the engine felt more powerful (possibly because way less false knock retard?). Try it out and let us know. It's 20-30 per can, but seems effective from my testing.
-Jason
KaPower
Postby benckj » Mon Jan 08, 2018 4:42 pm
Methanol is also a good additive directly to fuel. I routinely use 10-15% by volume in all my cars.
Jim
MSPNP v2 with 3.57 firmware
Toyota MR2 98 3sgte
TD05sl2-18g (billet wheel & high flow turbine)
A2W IC
WI with 50/50 meth/water
benckj
Postby Yves » Tue Jan 09, 2018 3:20 pm
benckj wrote:Methanol is also a good additive directly to fuel. I routinely use 10-15% by volume in all my cars.
Jim
I thought it doesn't mix well with fuel. I was told toluene was a better alternative.
Yves
Postby prof315 » Thu Jan 11, 2018 5:14 am
Keep in mind that things like forged pistons, solid lifters and stiff powertrain mounts can give you false knock readings. Racing suspensions can also produce false knock on road.
Linfert Performance: Come run up front
92 Corrado 2.0L ABA and Borg Warner EFR 6258 on MS3Pro.
94 Ranger 2.3 Twin Plug on MS2
Support the developers!
prof315
Postby Yves » Thu Jan 11, 2018 12:00 pm
prof315 wrote:Keep in mind that things like forged pistons, solid lifters and stiff powertrain mounts can give you false knock readings. Racing suspensions can also produce false knock on road.
Yes, the intention was to make sure I have a situation with no knock to set a baseline.
Yves
Postby benckj » Mon Jan 15, 2018 3:39 pm
I've done some tests and if using low mix ratios it mixes just fine. Much the same as ethanol. Toluene is expensive and I believe more corrosive to certain metals (ie brass, copper) than methanol.
Toyota MR2 98 3sgte
A2W IC
benckj
Postby Yves » Fri Jan 19, 2018 3:43 am
Are you sure about the corrosivity of Methanol vs Toluene ? I thought meth was rather corrosive ...
Yves
Postby Paul_VR6 » Fri Jan 19, 2018 4:28 pm
Methanol is generally much worse than toluene, especially when the methanol starts to absorb water.
-Paul
1995 GTI VR6 MS3/V3
Paul_VR6
Postby Yves » Sat Jan 20, 2018 3:43 am
that's what I thought.
Yves
Return to Tuning
