So currently I have a problem with a BMW M52TUB25 "dual vanos" engine running on MS3 1.5.1...
I have attached the plot from the DynaPack and MSQ. Issue is at around 4400-4800rpm the AFR value drops down below 10 and engine suffers enormous powerloss when boost comes on.
I have tried increasing Dwell without luck, and specifically removing a little fuel at specifically 4700rpm only to get a great spike before drop in AFR value.
Running engine without VANOS connected.
Specs are SuperT70 turbo, Siemens 850cc high-Z injectors and MS3 V3 ECU.
MS3 specs: Hijacked the 14CL36 ignition drivers from OEM ECU, running IRLR3103 mosfets for each injector MS3X style.
Tips and tricks are welcome!
MS3 dropping AFR value at ~4700rpm
- Attachments
- DynaPack
- IMG_20171227_205513-min.jpg (779.29 KiB) Viewed 361 times
- M52TUB28_Glenn.msq
- Tune
- (275.5 KiB) Downloaded 31 times
Re: MS3 dropping AFR value at ~4700rpm
Can you also post up the ECU's data log of what is going on?
How much boost were you running?
Your fuel and ignition map looks really odd to me.
Note that the req_fuel is way off; that's why the VE looks so strange.
Soo... After an excruciating fault finding mission I figured out that the CAM sensor was dropping out at 4700RPM.
For the guys pointing out that the VE table looks wierd, the Req.Fuel was wayy off and the Injector Dead Time was also set way to high. But thanks!
