Hi
Motec m1 has a feature where you can see when you are centred in a VE cell and then you can hit a hotkey where it then looks up your targeted afr value and correct your VE table. I know aem have a target cell too with a little cross too.
What do you guys do when you have the car on a load bearing dyno for fast tuning your VE table ?
Motec M1 VE vs afr lookup feature
Kent
Supra mk3 2jz-gte
Ms3pro ultimate (installing)
Microsquirt trans control (installing)
Denmark
Supra mk3 2jz-gte
Denmark
