No 3D Tuning Map
No 3D Tuning Map
Msdroid V2.4r1
Ms2extra 333e2
When i go to look at the VE 3D tuning Map i can only see a white screen and nothing else. If i look at the VE table i can see everything it just seems the 3D parts don't work
any ideas please
Ms2extra 333e2
any ideas please
Re: No 3D Tuning Map
help please
I get a white screen as well... so best I can say is that you're not alone. Although, my primary use isn't for tuning so it hasn't bothered me.
On both my Note 3, and my Tab S I have many blank tabs and not just tune 3D views. Is this normal and expected? I'll list all the missing elements if anyone is interested. It seems odd because I'd either expect the missing configuration options simply to be left out of the UI or have an indication that they are not implemented.
I'm aware that the 3D views are broken and it was intended to get them fixed quite quickly, but the months have rolled on and it hasn't happened. All I can say is that I know this looks bad and they should have either been fixed or left out of the UI for the time being until properly implemented again. I will look into this.
Thanks for updating this. It is good to know it isn't a device specific problem. A simple "not implemented yet" statement on the page would be a good short term work around. My comments are all meant to be positive and helpful.
Hi Nige, the feedback is much appreciated and I needed the kick up the bum to get this sorted. I have spent some time on fixing the 3D maps this weekend and it is looking good so far.
Good to know it was taken in the spirit intended. He's another one - I keep reading posts saying people think MSDroid is updating the connected controller when they haven't "burned" anything. Can this happen? Does it every write it's stored tune in preference to the tune on the controller? Also can you confirm that any updates made with MSDroid are totally compatible with TunerStudio as I use that as my main tool for updating tunes, but it would be handy to use MSDroid to make minor changes on the fly and then merge them with the main line on TunerStudio.
Thanks, Nigel.
Thanks, Nigel.
