msdroid always reading signature
Use and development of MSDroid tuning software on Android
Postby turbotankshane » Sun Mar 19, 2017 1:34 pm
I'm using a android 5.0 lollipop tablet, efianalytics bluetooth adapter. I've got successful pairing with the adapter, and I got msdroid to read the signature once and only once, and it told me it couldn't find my ecu definition on the server (msextra 3.4.2 firmware on microsquirt). I found my .ini and moved it into the same folder on the tablet, but ever since the first connection my tablet never gets past "reading signature." I've uninstalled/reinstalled the app, reset my connections and it continues to act the same. What do?
turbotankshane
Re: msdroid always reading signature
Postby Gamemaster442 » Thu Apr 20, 2017 6:52 pm
Same problem as above three different devices Bluetooth turns solid blue reading signature but never connects.connected one time at first then just reading signature. This is EFI Source Bluetooth module Insignia 7-inch tab I am not that computer savvy.
Gamemaster442
Postby Gamemaster442 » Sat Apr 29, 2017 7:01 am
This is what I receive from EFI Analytics
With the MicroSquirt you need to wire the power to the Bluetooth adapter so that it power cycles with the ECU. Also you want to make sure the switch position is closest to the antenna to make a connection.
Any time you make a connection and then loose it or shut the ECU off the Bluetooth adapter must be power cycled before a connection to the ECU will be possible that is why we recommend making the Bluetooth adapter power cycle with the ECU.
This option allows you to connect the power from an ign. source so it switches with the ECU then provides you with a USB connection so you can connect to the Bluetooth adapter.
https://www.amazon.com/GEREE-Converter- ... +converter
This is a cigarette cell phone charger, they usually cycled with the ignition so it would work as well.
https://www.amazon.com/RAVPower-Aluminu ... ll+charger
Thanks,
Brian H
EFI Analytics Inc
This works ... :yeah!: I was using the wall charger and not cycling each time
Gamemaster442
Postby turbotankshane » Mon Jun 19, 2017 6:15 am
Ok, thanks for the reply. I got a new cigarette lighter outlet and wired it to ignition so the Bluetooth adapter cycles with the micro every time. So now it gets past the connection but it now won't ever get past "reading signature" again. It's been connected fine before, so I know I have the right .ini and all the right connection settings but it won't fully connect still.
turbotankshane
Postby MS2tester » Sun Jul 02, 2017 6:27 am
if you can get it to work
you might wanna check out a rasberry 3!
if you disable the touch sceen ( red wire) by hand or toggle switch you can boot it to a big screen
also less hassle with can modules
MS2tester
Postby MS2tester » Sun Jul 02, 2017 6:30 am
:yeah!:
MS2tester
Postby NiceMan » Fri Jul 07, 2017 9:44 am
I fight this program, we have BT and its connect to MS3 Pro Ultimate, tablet is paired whit ms3 nice but msdroid only show xxx.ini and its think this file easy 30min and nothing happend...
Possible 2-3 time get it work but... its too bad.
Its need get work more faster like 1-10 second.
http://www.theniceman.com/
Ford Taunus Coupe 1975 2.0i Turbo
Ms3 + MS3x
NiceMan
Postby NiceMan » Fri Jul 07, 2017 9:58 am
Ms3 + MS3x
NiceMan
Postby MS2tester » Fri Jul 07, 2017 10:31 pm
Have tried putting the proper. ini in this folder?
It might be neccesary to restart the tablet to clear the program cache
2017-07-08 07.32.27.png (100.06 KiB) Viewed 229 times
MS2tester
Postby NiceMan » Sat Jul 08, 2017 11:05 am
*.ini is right and its copy to tablet and right tune copy there too, its sometime works but most time not...
Ms3 + MS3x
NiceMan
Postby turbotankshane » Thu Sep 21, 2017 11:11 am
I never was able to get it to work with the bluetooth adapter. I caved and bought a $6 android otg cable and it works great every time since the first time I plugged it in.
turbotankshane
Return to MSDroid
Users browsing this forum: Baidu [Spider] and 2 guests
