hai
I had installed from goole play ms droid
it works right, only tuning ve and spark, I can not set anything
I only see a black screen ,with the top in the left , VE Table 1, with the same spark.
.here you would surely be able to put the numbers higher or lower in the tabel.
i use a ms1 with v3board and the latest firmware
or should I buy pro,,,,??
What could be wrong
msdroid in tuning work ve and spark table not
Re: msdroid in tuning work ve and spark table not
Any joy with this?
I have the same questions
(and the same blank screen)
If you go into the basic settings the spark and ve tables are there on my devices- and I have a "live" dot showing which bin is active (using a stim for testing)
I'm still learning how to drive msdroid and I'm sure I have missed a manual or something
Still trying to work out if I need to buy pro to get the other stuff showing up?
Regards
Rob
Regards
Rob
