What we've done is set up an MSDroid page on JustGiving to raise for cancer research:piledriver wrote:You guys need a "donate" button on the Play store so we can buy y`all a beer occasionally.
http://www.justgiving.com/MSDroid
I'm still getting a failed connection - during the "reading signature" phase in the status page I see these 3 strings...Trev16v wrote:Will investigate MS3 issues tonight.
The signatures are different and match the ini files.gslender wrote:Ahh, that would be it!
So does the fact that the firmware sig is the same but the ini revision is different cause problems? Eg. The ms3pro ecu signature is the same as the std ms3 sig, but they require different ini files I think....?
Mmmm curious, what part of the sig above in point 1) changes to show it is from a ms3 pro?jsmcortina wrote:The signatures are different and match the ini files.gslender wrote:Ahh, that would be it!
That's the version string, not the serial signature.gslender wrote:Mmmm curious, what part of the sig above in point 1) changes to show it is from a ms3 pro?
G
Yes, terms are confusing!?jsmcortina wrote:That's the version string, not the serial signature.gslender wrote:Mmmm curious, what part of the sig above in point 1) changes to show it is from a ms3 pro?
G
After placing the ms3pro.ini in the correct /msdroid/ini location, the app now connects and works. Great!gslender wrote:I will try and copy the ini into the SD card on the phone in the next few days when I get back home.
