- Added log size in the "View logs" activity.
- Added auto-connect option in preferences to automatically connect to the last known ECU on app startup.
- Added a "lock dashboard orientation" option in preferences to lock the dashboard in a specific orientation.
- Added a "Prevent sleep mode" option in preferences.
- Added a "Disconnect from ECU" option from the main menu.
- Added option to convert a datalog to .msl format before emailing.
- Added a splash screen presenting the app and developers.
- Fixed hanging at "Reading page 0" for MS3 firmwares that don't support CRC32 validated protocol (Older then 1.1).
- Fixed newly added ini not being picked up by the app (Fix "no matching ini found" when you just added it).
- Fixed the delete log option in the "View logs" activity not working.
- Fixed crash when the last used ini couldn't be found.
- Fixed various file descriptors and resource leaks.
- Fixed menu in tuning section that were duplicated under specific conditions.
- Enhancement: Logging menu now reflect logging state (Start logging when not logging, Stop loggging otherwise).
- Enhancement: Sort source names in widget settings alphabetically to make finding the source you're looking for much easier.
- Enhancement: Sort available series in datalog graph settings alphabetically for same reason as above.
- Enhancement: Overwrite debug log when it gets too big (> 5MB).
Regards,
Dave
