- Added a progress dialog when converting a datalog from MDL to MSL before emailing
- Added support for tuning fields expressions (properly enable/disable features in tuning section based on status of other fields defined by firmware INI)
- Added support for the std_injection and std_constants dialog, also include the required fuel display and calculation
- Added support for table being used as panel in tuning section (such as Idle VE on MS3)
- Added support for std_accel (Acceleration enrichments on MS1/MS2/MS3 1.1 and less)
- Added basic play/stop/rw/ff functionality to the log viewer (will be improved later)
- Fixed VE/Spark table causing crash on MS1
- Fixed some gauge designs having wrong pointer angle
- Fixed Bluetooth connect issue
- Fixed ECU disconnect option
- Fixed Bluetooth device selection (no need to restart the app anymore when changing bluetooth device)
- Fixed "Burn" button not always being enabled in tuning section
- Reading ECU signature connection state should now be faster (~4 seconds saving)
MSDroid 0.3a2 Change Log
0.3a2 has just been pushed to Google Play so expect to see an update notice on your device. The changes made are :-
MSDroid More than just a dashboard.
Do you like the application? Make a donation to Cancer Research UK on our behalf http://www.justgiving.com/MSDroid/
Re: MSDroid 0.3a2 Change Log
This application remains free, but if you like it and want to donate, please help our chosen charity:
Thanks to those who have done!
It's nice to see someone ask for donations for actual work, then give it to charity. As opposed to folks on XDA who ask for money for themselves after adding color to apps.
Great job.
Great job.
