mk808 usb
mk808 usb
well I tried to hook up ms3 to mk808 from USB port on ms3 to USB otg. MsAndroid had hardware/android version message. I'm going to do some looking to see if I need to turn something on or download an app. Any suggestion welcome. Thanks for your hard work.
62 f100,uni body,4.6 motor&updated chasis, ms2 micromodule
Re: mk808 usb
It should work. Remember to connect the USB before starting the app or tap the back button and open the app again if you connected the USB device after the app launched. This will obviously be fixed so that the connected USB device is recognized right away when connected, but it should still work if you restart the app now. Also, try the full size USB port too just in case...
You basically have to see a request permission prompt and I think you have to restart the app again after that... The USB connection is not super user friendly right now that's why we haven't made too much noise about it but it will get better soon. Once its connected tho, it should be pretty solid (and better RPS than bluetooth )
I think you're the first to try an MS app on an Android mini pc so I'm curious of the result
1993 Chevrolet Cavalier Z24
MS3 v3.57+MS3X
MS3 v3.57+MS3X
Re: mk808 usb
was watching a YouTube video about mk808 &storage device. They were use a USB hub & then the 808 would see the external hard drive. I'm wondering if I have the and thing going on. I'll give it a try tomorrow . Thanks for the great work you the guys are doing.
Re: mk808 usb
also tonight was the first time playing with the app in a real setting & turned on the Bluetooth search. How can you go back or will it time out if you don't pick a device? I forced app closed to restart it. Thanks again.
