Are logs supposed to save if the car is shut off or...
Is there anyway to have a datalog save when shutting off the engine or exiting the app? I blew a headgasket last week while logging and then I shut the car off, also I merely closed the app after shutting down. I came back later after remembering I was logging and the log is not there! I am totally bummed I don't have any data from the head gasket failure.
MS3 3.8L Buick Turbo V6 -- 1968 Chevelle
MS3 2.4L Honda K24 -- 1991 Toyota MR2
Re: Are logs supposed to save if the car is shut off or...
Hmm, once it has started the log, the file should certainly be there. Is it actually possibly the case that there is a file there that just shows no data when viewed? If that's the case I think I could repair it.
Yes i do have a fike but with nothing showing. Should i email it?
Email or attach to this thread, we will definitely take a look!
1993 Chevrolet Cavalier Z24
MS3 v3.57+MS3X
MS3 v3.57+MS3X
We know the reason now. It's quite simple so will be sorted. We could fix your MSD log for you, but in actual fact Piledriver in the other thread has pointed out that it converts to MSL format just fine and then can be viewed in MegaLogViewer. You could try that in the meantime to view the log taken during your head gasket failure.
Finally found my tablet after moving things around in the duplex haha. I will convert to msl and will post if there happens to be an issue. Thanks for the help!
