Hi folks,
Thanks for the first App that enables me to change a tune using my android device! I have waited for that a long time!
After a recent update of the msdroid app with 3D tables I am now unable to switch to standard/2D table VE1 table? I am not able to change the values in 3D mode and is now stuck since I do not find a way to display 2d tables. Is it a hidden setting or button that is used to switch between 2D and 3D?
Hakon
How to switch to 2D table view?
Megasquirt project car: Escort mk2 Mexico replica with 2litre Zetec on GSXR ITB's. Sequential injection and spark . MS3 with ms3x.
Re: How to switch to 2D table view?
It always depends which firmware you're using. I will assume some ms2 extra since that is what is in your sig. The 2D table are usually in "Basic setup" menu instead of "Tuning" menu. If you use the Tuning menu, you will get 3D tables.
1993 Chevrolet Cavalier Z24
MS3 v3.57+MS3X
MS3 v3.57+MS3X
I figured out - I think. In the tuning menus I found a setting where I could switch from "fuel only" user to "advanced" user and then I got my 2D table back in VE table view. Yes, I am using ms2 extra.
Since the 3D table is not editable - how can one switch back and forth between 2D/3D? 2D when editing VE table and 3D for viewing?
Hakon
Hakon
As I said, 2D and 3D tables should be in two different menus section so you just have to go into whatever section you want.
3D tables will be editable at some point, we just had to start somewhere.
MS3 v3.57+MS3X
MS3 v3.57+MS3X
