MS2Extra comms332mM ini
upgraded to 332mM & wondering if theres a ini for msdroid? can i just use same file used for TS ? i was using 331 & had no VE fuel table which i think i had when i first used olboy ini,so thought i would upgrade & before i put anything in the file just wanted to check.
62 f100,uni body,4.6 motor&updated chasis, ms2 micromodule
Re: MS2Extra comms332mM ini
Let me look through what I have at work. I'll post a nodded 3.3.2 usquirt module INI.
Sorry, took me longer than I thought.
I have not tested it yet but I referenced it from my working 3.4a2 ini file.
Does anyone know what changes are done to the ini files between each alpha, beta, release code.? I was lazy on 3.3.2 betaxx and just changed the signature a the top of a working 3.3.1. Would be nice if we can create an ini file that just has the basics, fuel VE, spark, EGO, Warmup, IAT stuff, idle control and the start up curves. Most if not all these features are tried and turn and don't change much. The only feature that might would be the idle stuff. From what I can see MSDroid can't change every setting anyway. I tried going from 2 squirts alt to 4 squirts alt and it didn't stick. Changing the required fuel number didn't stick either. If your just tweaking the VE and spark table with your phone then 98% of your tune is set and would need the laptop to make major changes.
Later Ryan
Later Ryan
Install diff and find out.ol boy wrote:Does anyone know what changes are done to the ini files between each alpha, beta, release code.?
Bad idea, don't do that.I was lazy on 3.3.2 betaxx and just changed the signature a the top of a working 3.3.1.
been busy & haven't downloaded it , but see two downloads. anybody have feed back before i download?
Sorry you guys are still having to jump through these hoops -- I thought I'd have V2 released by now but I seem to keep wanting to pull it to bits again. (Rather like my car, really.)
downloaded & connected to my galaxy s3 phone. gauges seemed right reading & changed vetable. Thanks olboy.
That's good to know. Glade its working for you.
