msdroid can't read what ecu that I have
Finally changed baud rate to 11500 on the blue tooth and hooked it up to microsquirt v3........................msdroid couldn't figure out what ecu that I had............and another time I tried it said something about ini file. Anybody got this thing working at all?
Re: msdroid can't read what ecu that I have
yes had it working till i upgraded to newer firmware. right now they are working hard to release next version & my understanding is version were using is done & without changing parts of the INI the newer firmware wont work. i havent played with changing INI,but if you post what firmware maybe someone can post modified INI. this is just what im understanding from reading & responses from trev.
62 f100,uni body,4.6 motor&updated chasis, ms2 micromodule
Yep - just to confirm working hard on cranking out the next release as we speak. It'll solve these issues. Bear with me
I am running 3.3.1 firmware, I haven't updated to latest 3.3.2 firmware yet. I don't think updating the firmware is going to solve msdroid issues. The only other option I have is with shadow dash........but from what I've read in the shadow dash section it's either been abandoned or lots a people having problems with it. I am not trying to spend money where it not need to be. Guess I am just going to keep on riding with a laptop strapped to my bike just to log it and tune it.
Which ECU type are you running at the moment? MS2, Microsquirt, Microsquirt Moduel, pnp...? I have posted some revised INI files to cure the MSDroid issues until the new release hits.
62F100.. Did you try the Micro Squirt Module INI for 3.3.2 yet? I haven't seen anyone saying it not working.
sorry i havnt had time. tomorrow ive got to make some time. 3.3.1 the VEtable was not there. i could swear it was there at first but when i went back it wasnt. i have TS for my laptop so ive been using it to solve the problems ive been having tuning. tomorrow i will down load & report on 3.3.2 for micrco module that olboy posted.
Running a microsquirt v3 with 3.3.1 firmware for now, will probably update to 3.3.2 unless I can get msdroid to work with 3.3.1 and not 3.3.2 then I am fine with 3.3.1.ol boy wrote:Which ECU type are you running at the moment? MS2, Microsquirt, Microsquirt Moduel, pnp...? I have posted some revised INI files to cure the MSDroid issues until the new release hits.
Oh. I haven't modded an INI file for the microsquirt v3 stuff yet.
i downloaded the micro module ini for 3.3.2 that olboy posted & although i didnt comfirm every thing, i can change VEtable & guages seem correct. galaxy s3 phone used to confirm.
How do you mod an ini file?
I tried hooking the blue tooth up again today and it keeps giving me random results, one of them was this.
Then I decided to try shadowlogger...........it would connect to blue tooth for 5 seconds and then disconnect for few seconds and connect again. Then I disconnected blue tooth and connected it again and it showed this, but it didn't last long, was less than 3 seconds. Trying to figure out what the problem is, blue tooth or something else.
If you can hold out until Monday I can do you a modded INI file for microsquirt v3.
I have nothing but time, I can live without it, but it would be nice to have. I am just amazed that microsquirt v3 right out of the box that has been around for a while isn't supported.ol boy wrote:If you can hold out until Monday I can do you a modded INI file for microsquirt v3.
Its not that its not supported... I was only modding the INI files as people asked for them. Your the first with a microsquirt to need it. 62f100 and I both need the INI for the microsquirt module but my daily driver is a plain ms2. Know one has asked for a PNP..
I know its a pain in the butt, we will get you going though.
*** edit. I'll mod 3.3.2. I'll start a new thread and label it.
Hey go ahead and mod 3.3.2 instead of 3.3.1, I will just switch since it's a newer firmware, hopefully more people will be able to use it as well.
Thank you.
Thank you.
posted 3.3.2 uS v3 ini please test.
Tried it but it didn't work.
What did it do or not do?
