Modded INI for MS2 and MicroSquirt V3 3.3.2r
ol boy
Post by ol boy »
This 3.3.2r INI mod needs to be tested to confirm it works. This is only for microsquirt cased units V1 thur V3..? I followed the same wisdom as all other INI file changes. Enjoy
microsquirt.ini
megasquirt2.ini
Later Ryan
**edit** added MS2 support.
**edit2** found an error in the microsquirt ini... I missed a line please add this ini file to your ini folder within MSDroid, when asked "copy and replace", yes.
ol boy
Re: Modded INI for MS2 and MicroSquirt V3 3.3.2r
Post by ol boy »
I missed a line in the microsquirt ini. I fixed it and reloaded it above.
For the 3 people that downloaded it please download it again and place back into the ini folder within the MSDroid app.
Tony Evo
Post by Tony Evo »
With the ini file for Megasquirt 2 ,Msdroid return at work perfectly.
thank you.
acedeuce802
Post by acedeuce802 »
I haven't been able to get either of my phones working on 3.3.2. I've tried on my Samsung Galaxy S3, and I now have an HTC One M8 running 4.4.3. My ECU is a DIYPNP with Microsquirt Module in a '99 Miata. I deleted all the other ECU .ini's and placed the Microsquirt .ini to the ini folder in MSDroid. It worked flawlessly when my ECU was on 3.2.x firmware. Any ideas? Thanks!
ol boy
Post by ol boy »
Yes, You need the INI for the microsquirt module not the microsquirt cased versions. Confusing I know. :roll:
check here for the module ini
http://www.msextra.com/forums/viewtopic ... 36&t=54662
I got to thinking about your PNP... I'm not sure I steered you in the right direction.
acedeuce802
ol boy wrote:Yes, You need the INI for the microsquirt module not the microsquirt cased versions. Confusing I know. :roll:
That worked for me, thanks! :D
