Cant find VE table
Cant find VE table
Am I just overlooking it? I can find spark table in ign but VE table isnt under fuel settings. AFR target is under fuel settings.
98 neon Srt-4 swap | MS2 3.0 board 3.2.1 firmware| 18psi on a 20g
Re: Cant find VE table
need to know which INI file your working with, firmware, ect....
Its in there, I used that INI file for several month tuning my wagon from my phone. Can you post a screen shot of the page after you hit the tune button? Then another one after you hit the fuel button. Can you scroll down on that page?
Can you post your INI file on here for me to have a look?
Okay, last chance from me tonight. I'm in the middle of class right now.
I unzipped the 3.3.1a code and modded it's ms2 ini file. comms...330N2
delete the ms2extra.ini that you are having issues with before adding in this ini.
Thanks man! That fixed me right up. I ended up not reflashing computer. The ini was a easy fix.
Glade we got it all worked out.
