ms3 1.3.0 error.
ms3 1.3.0 error.
hello. i was trying msdroid with ms2 and it works greeeeeat when i put ini file in msdroid folder.. so i try with ms3 but it dont work even when i put ini file in msdroid.
i can upload ini file because its 8xx kB.
Re: ms3 1.3.0 error.
thankyou very much for your help.
I don't know if it is related, but the text shown in the "ECU Signature" box isn't the signature, that's the version.
Going to toss a SWAG out there and say that the MS3 INI may also need modded to work correctly with MSDroid. If my memory serves me correctly all the INI files a few months before March 2014 changed to accomindate certaint versions of TS which broke the way MSDroid would use the INI file. I'll download the zip and take a look.
**Edit** Give this one a try. I commented out the tuner studio part and resave it back into your MSDroid INI folder. I guess attachments are limited to 771 KB...? needs to be at least 1MB.. ugh.
Code: Select all
[MegaTune]
MTversion = 2.25 ; MegaTune itself; needs to match exec version.
;[TunerStudio]
; iniSpecVersion = 3.0
#if CAN_COMMANDS
versionInfo = "r\$tsCanId\x0e\x00\x00\x00\x3c" ; Title bar
queryCommand = "r\$tsCanId\x0f\x00\x00\x00\x14" ; Verify against signature.
this is in ini file.
[MegaTune]
[TunerStudio]
#if CAN_COMMANDS
#else
versionInfo = "S" ; Put this in the title bar.
queryCommand = "Q" ; Verify against signature.
#endif
signature = "MS3 Format 0434.01 " ; MS-II sends a null at 20th byte.
; 123456789.123456789.
#if INI_VERSION_2
; ok
#else
#error Megatune cannot be used with MS3 - please upgrade to TunerStudio
#endif
[MegaTune]
[TunerStudio]
#if CAN_COMMANDS
#else
#endif
#if INI_VERSION_2
; ok
#else
#endif
so i dont understand what to do or if there is some patch i can use. thankyou very much.
Then make it read this... ;[TunerStudio]
;iniSpecVersion
Resave and give it a try.
[MegaTune]
;[TunerStudio]
#if CAN_COMMANDS
;iniSpecVersion
[MegaTune]
;[TunerStudio]
#if CAN_COMMANDS
no lucky. i send an email with log from msdroid app.
same error as the above picture.
Any luck? i have same problem, tried remove tunestudio lines but still not working.
not yet.vtux wrote:Any luck? i have same problem, tried remove tunestudio lines but still not working.
Which we the last MS3 version to work correctly with MSDroid?
i upgrade from ms2 to ms3 and start with 1.3.0 firmware.
Oh I c.. I need to know which was the last MS3 firmware that worked. If I know that I can compare the INI files to see what might be different.
i did 1.3.2 upgrade. msdroid works fine with this firmware.
Good to know. I wonder what the difference is in the INI file...
